Is a ls2 gto oilpan the same as ls1 gto oil pan
I ran into a good deal and wanted to make sure.
Is a LS2 GTO oil pan and front sump assembly the same as a LS1 GTO oil pan setup?
Also since I'm already here. I'm running -6 lines for fuel, what do you recommend as far as a FPR?
Also I'm trying to order the special fittings to use on the stock rail
http://store.summitracing.com/partde...art=RUS-640850
and this is a 3/8in or -6
http://store.summitracing.com/partde...art=RUS-640860
it says its a 5/16in so in other words it uses a -5 line for fuel supply Why would the supply line be a smaller fitting.
Thanks ronald
Thanks ronald
