LS1 VE Tables
LS1 VE Tables
Has anyone here figured out the units that GM use in the main Volumetric Efficiency Table (VE)? I have been using LS1Edit on my 2001 LS1 powered Holden Commodore SS and looking at the VE table it refers to: "(Gms of Air) Load vs RPM" but this does not seem to correspond with gm/cyl fill. For example, the range for gm/cyl fill should be 0.08 - 1.2 gms/cyl (see one of the octane advance tables) but the VE figures for my car are in the 1100 - 2600 range. Either GM have applied a multiplier or the VE figures are something else like total air sucked in by the engine per minute.
Also, are these values calculated at a particular temperature?
Many thanks
Many thanks
