air pump
air pump
would my car make a wierd noise when excellerating if my air pump went out It showed a code and it the air pump but i wanted to see if it would cause the noise and make the engine lose power when excellerating from a roll. Can't really describe the noise but it only does it everynow and then and only when i excellerate when rolling so any help would be apperiated thanks
The air pump is electrically controlled/not belt driven, so most codes will be for it not coming on. They can make noise if going bad, but run mostly during cold starts only for just a few minutes. Post the code, but sounds like something else is going on.
Don't think it's related to your noise/power loss. More info on P0410 at www.gearchatter.com/viewtopic9141.php
