overheating (cooling fan fuse)
Old 06-12-2007, 08:55 PM
scott5586's Avatar
Default overheating (cooling fan fuse)
On my 02 camaro ss, the fuse that controls the cooling fan keeps blowing. I was sitting at a red light and i noticed that my a/c started blowing warm/hot air and my temp went up. well i found a blown fuse that controls the cooling fan i replaced it and started the car and then the fuse went out again. i was wondering if anybody had any similar problems???
Old 06-13-2007, 03:22 AM
staringback05's Avatar
when fuse's keep blowing that usually means you have a bad ground somewhere or a bad load on a wire
Old 06-13-2007, 08:26 PM
Flawless02SS's Avatar
I would look under the car near the fans and make sure you have no naked wire touching something. Thats probably all it is.
Old 06-19-2007, 06:13 PM
scott5586's Avatar
i went to autozone and ran the scanner and it came back as one of my relays are bad. if a relay went out would that keep poppin the fuse???
Old 06-19-2007, 07:05 PM
2001NBMZ28's Avatar
Did autozone give you a code?
Old 06-19-2007, 08:11 PM
Formula413's Avatar
There's a code for that? Or is that just Autozone being Autozone? You could certainly try replacing the relays, they can't be that expensive. Let us know what you find.
Old 06-20-2007, 04:06 PM
scott5586's Avatar
the codes it threw was p0480 and p0481. i replaced both fan 1 and 2 relays and put a new fuse in. started it up and "pop" there goes the fuse. so now i guess its gotta be something with the wires??
Old 10-03-2007, 11:25 AM
Bad Blue WS6's Avatar
any conclusion on this?
