Front wheelhub help
Old 06-12-2007, 09:35 PM
CoopDog's Avatar
Default Front wheelhub help
Does anyone know how to seperate the front axle hub from the bearing carrier? I'm sure that you start with the plastic end cap that houses the sensor connection. There are two notches on either side of the plastic cap, I'm sure they are for an expensive Kent/Moore tool. I'd guess the cap has to rotate somehow. Any ideas?
Old 06-12-2007, 10:27 PM
mitchntx's Avatar
That plastic cap is just a dust cover. You can knock it off like a regular bearing dust cover.
But, there isn't much to see inside ...
Old 06-12-2007, 10:43 PM
CoopDog's Avatar
Thanks. I mainly want to throw this in the blast cabinet, I didn't want to do it with the bearings installed. I didn't want to do anything with the cap until I knew it was ok to bang on it.
Thanks again-
