6 speed traction question
Old 06-12-2007, 10:08 PM
volksmech1's Avatar
Default 6 speed traction question
so what mods have the 6 speed guys done to get the car to hook from a dig. the auto guys have it easy.
so my car is down right now for a trans rebuild and clutch install (spec 3, drill mod and am making the stock master cylinder adjustable)
i have a set of 275/40/17 mickey thompson drag radial and lower control arm relocation brakets as of right now. cutting a shitty 1.9 60 foot.
in the mail i have the adjustable lower control arms and pan hard bar with polly bushings. and will i take the front sway bar off the next time i go to the track.
with the clutch install i should be able to slip the clutch a little better so the tires don't blow off.
after all the explaining my question is how are the 6 speed guys getting thier cars to hook better and what is the best method you have found to lowering the 60 foot times?
Old 06-12-2007, 11:12 PM
cody161's Avatar
my buddy has an 01 trans and the adj torwue arm with relocation bracket helped him out sooooooo much. do the torque arm def and it will help a lot BMR by the way call and ask them to knock a little off the price when he talked to them they said anyone who actually calls them and ask they most of the time give them some off
Old 06-12-2007, 11:14 PM
cody161's Avatar
he is making 470/472 and hooks a lot better...and a 1.9 60' is pretty good lol im getting a 2.2 with m6 making 331/335 but should be closer to 345/350 now
Old 06-12-2007, 11:18 PM
volksmech1's Avatar
i have a e mail in to texas speed about which torque arm will fit my car because i have thier true dual system and it is kinda tight under there so i just wanna get the right one the first time. as for my goal. i want a 1.5 or better. a few auto cars are hitting 1.5 60 foots and i want to do it in a 6 speed car
Old 06-13-2007, 02:57 AM
flash12t's Avatar
lose weight, gears, and slicks
im on the same boat 2.0 is my best on a nitto . .stock suspention im betting relocation brackets. . same clutch . . i rev to any where from 2500 to 4000 depends on track and slip it out. . but my clutch doesnt like me much
Old 06-13-2007, 03:08 AM
DaGeneral's Avatar
I pulled a best 60' of 2.005 in a 295/35/18 tire with 4.10's...
I just have an adjustable UMI torque arm, as far as suspension goes.
Old 06-13-2007, 06:34 AM
coolformula's Avatar
I think a good pair of shocks help
Are you talking on the street or strip?
Old 06-14-2007, 12:42 PM
SIC LSX's Avatar
what psi are you using? the best i have seen was 22psi! if i went any lower it would spin! Best 60ft was a 1.6 not my car a friends but i have made many passes in it! Stock socks and springs up front and comp drag shocks i rear and umi torq arm set a -3 this was in a cam only vert with 3,900lbs race weight! We got a 1.5 60ft on a 75 shot and ran a 11.00
Old 06-14-2007, 01:00 PM
volksmech1's Avatar
i roll around on the dr's at 20 psi. i have aired them down to as low as 13. a couple people are talking me into a set of adjustable shocks before the torque arm so that will probably be my next purchase
Old 06-14-2007, 01:28 PM
SIC LSX's Avatar
when your running 17" wheels you shouldnt go that low! The tires start to cup! Try 22psi next time at track! Thats the biggest problem with people running 275/40 17's They let to much air out!
