LS2 and Z06 Clutch
Old 06-13-2007, 08:48 AM
Deeavi's Avatar
Default LS2 and Z06 Clutch
Will the Z06 Clutch Kit work wth an LS2 Engine? It should cause it comes with the flywheel. Has anyone done this on a late model GTO?
Old 06-13-2007, 08:12 PM
JonB's Avatar
Are you talking ls7 Z06 or ls6 Z06. I would not recomend the ls6 as that is what came in 01-02 camaros and will light mods they tend to eat those clutches up. The ls7 is the clutch you want and should do just fine on a lightly moded or stock GTO. Yes the ls7 with work with the ls2 without a problem.
Old 06-13-2007, 08:38 PM
Deeavi's Avatar
The LS6 Z06 Is pretty good clutch setup for a street car for up to 400 rwhp. I am selling the one out of my car, because I am installing a 416 stroker motor. I am going to go with the LS7 myself.
The reason I was asking is that someone wants to buy my Z06 setup; flwheel, pressure plate, and clutch disc - only have 4,000 miles on it.
He has a 2005 GTO. I believe it will work for him since he will be changing the flywheel along with the clutch. I just wanted to make sure that the LS6 Flwheel would work with the LS2 in the GTO
Old 06-13-2007, 09:29 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
Get ahold of Matt at SDPC, he should be able to give you the answer
Quick Reply: LS2 and Z06 Clutch
