Wiring Harness ID Needed
I have identified most of the connectors on my newly-acquired LS1. I don't know about the others because the engine was already out of the donor car.
A bigger version of the photo is at http://rides.webshots.com/photo/2626...37506119Blfqsi
Connectors I think I know:
1
2
3
4
5
6
7
8
9
10 Oil Pan
11 Ground
12 Crank Sensor
13
14 Cam Sensor
15 Injector
16 Injector
17 Injector
18 Injector
19 Right Coils
20
21
22 MAP
23 EGR
24 AC
25 Oil Pressure
26 Ground
27 Ground
28 Injector
29 Injector
30 Injector
31 Injector
32 Knock Sensor
33 Vac Valve A
34 Left Coils
35
36
37
38
39 Temp Sensor
40 Manifold O2
41
42 Vac Valve (TB)
43 IAC
44 TPS
45
46 Red Wire
1
2
3
4
5
6
7
8
9
10 Oil Pan
11 Ground
12 Crank Sensor
13
14 Cam Sensor
15 Injector
16 Injector
17 Injector
18 Injector
19 Right Coils
20
21
22 MAP
23 EGR
24 AC
25 Oil Pressure
26 Ground
27 Ground
28 Injector
29 Injector
30 Injector
31 Injector
32 Knock Sensor
33 Vac Valve A
34 Left Coils
35
36
37
38
39 Temp Sensor
40 Manifold O2
41
42 Vac Valve (TB)
43 IAC
44 TPS
45
46 Red Wire
