A/C blows hot
A/C blows hot
Hey guys, when I turn the AC on, the compressor blows air, it just comes in at outside temps. Not cool when its about 100* outside. Low Freon?? if so, how do i replace it?? Is there something else I could be missing?
-Charlie
-Charlie
More than likely you are low on freon, does the compressor come on at all? If not you are probably low on refrigerant. You fill it on the low side of the A/C line, R-134 has 2 different size fittings so you can't mix them up when adding R134.
no when you are filling from cans you are suppose to have the engine running and at set the A/C to MAX A/C, also you fill it with the can upside down.
edit: make sure you don't overfill it.
