rescaling fuel gauge for ls ls- s10 swap.
Old 06-14-2007, 04:03 PM
01WS6/tamu's Avatar
Default rescaling fuel gauge for ls ls- s10 swap.
Can the fuel gauge be rescaled in the ls pcm from the 270 full 33ohm empty like a camaro uses to 250 full and 40ohm empty to read correctly for my 02 s10. If Black x happens in here jhankinson said you got yours fairly close. Would someone mind giving up the figures on how to do it and get it right.
Old 06-15-2007, 08:35 PM
99 BUCKET's Avatar
If I am not mistaken X and I are running the same. I found a tune on the hptuners site that was from a late model 4.3 s-10. I copied the gauge info and used it in my tune.
Old 06-16-2007, 12:44 PM
01WS6/tamu's Avatar
Ok Thanks. I am guessing it will let you cut and splice different sections of the program as you need to then?
