drivers side front blinker bulb??
Trans am or Camaro? If it's a Trans Am you can reach into the hole under the daytime running light and it's right there. Assuming you don't have gigantic wrists or something. Otherwise you have to go underneath the car and undo a couple of screws and drop the plastic access "door". Still pretty easy.
EDIT: Sorry just saw the SS in your name...just use the access panel underneath!! May have to jack the car up a little.
Originally Posted by WhiteBird00
Blinker fluid: http://kalecoauto.com/index.php?main...&products_id=6
