Dynamometer Results & Comparisons - Dyno results full bolt on's M6 2001
LS1crazy01
06-14-2007, 06:24 PM
Speed inc. Just tuned my car and did a pull and the results were, 357.05 HP and 369.74 ft/lbs of tourqe. Mods in sig.
BriancWS6
06-14-2007, 06:47 PM
Strong numbers man :)
LS1crazy01
06-14-2007, 07:33 PM
Thanks man but to tell you the truth I thought it would have made a couple more. But considering the conditions were at 88* F and 36% humidity Its pretty good. Plus the Air filter hasnt been cleaned since last year.
MikeG
06-14-2007, 07:36 PM
Yeah it would have probably made mid to high 360s in better air.
Nice numbers
BriancWS6
06-14-2007, 07:38 PM
Well, was it not SAE corrected? Do you have the graph?
LS1crazy01
06-14-2007, 07:45 PM
How do you tell if it was corrected? It says on the top right (CF: SAE Smoothing: 5) And the bottom were it says the power and run conditions it says (SAE 1.03)
BriancWS6
06-16-2007, 06:10 PM
Ok, then it is SAE corrected. With that said, the weather isnt an issue when you dyno. The weather station of the dyno is designed to bring everything to a "standard". If you were to check the un-corrected numbers on that very day, it would have most likely been lower. Go back in the winter, they would be higher. If you use the corrected numbers, you will always have some consistancy to go by.
ScreaminRedZ
06-16-2007, 06:14 PM
Very strong numbers! Now it needs some track numbers :D
Redlinez
06-18-2007, 09:15 PM
Awesome numbers, especially the torque IMO without a cam. I guess I have something to really look forward to when I install my QTP's.
MannyZ28
06-20-2007, 09:36 AM
What's really sad is that you made more torque than me....and I have a cam!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
