knock sensor
Old 06-14-2007, 06:33 PM
01trans am's Avatar
Default knock sensor
okay my car makes a noise when exellerating from a roll like 40 to 70 so i took it to a shop and they said it could be the knock sensor. So i guess i'm asking if it could make the engine run like it is and is $475 sound like a good price to get it fix. thanks for the help
Old 06-14-2007, 09:22 PM
SlowazzVette2's Avatar
So they are not sure what the sound is basically judging by by them telling you that it could be the knock sensor. 475 seems steep to me but thats only because I dont know the price of knock sensors. It maybe a fair deal but Id buy the sensors after I pulled of the intake manifold and checked to see if anything was even loose where the sensors are. Also Id recommend that you hook up with your local fbody guru and say what they may say.
Old 06-14-2007, 09:28 PM
5_02ls1's Avatar
so the car has detonation when in a pulll....what gas are you runnin"gradw"??/
take the car to autozone they scan for free....475 is outragiously high.....
Old 06-14-2007, 09:36 PM
lovin myls1's Avatar
I didn't think the knock sensor makes noise.It only senses noise caused by other things, such as a knock from low grade of fuel or detonation?
In reaserching for my LS6 intake install,I saw some pics of the well where the sensors are mounted and some filled with moisture.That could probably cause a problem.
I would be a little leary of any shop that said it could PROBABLY be something or other.Just a thought.Get a second opinion.
Old 06-14-2007, 10:54 PM
01trans am's Avatar
i'm running on 87 octane and it doesn't have a code the guy said that moisture could get in it and mess it up without it telling the computer that it wasn't working and i think the sensors cost 75-100 dollars i think its high to i was planning on putting headers on my car but with this looks like i'll have to wait
Old 06-14-2007, 11:32 PM
TheLS1Kid's Avatar
Try running 93 octane and see how it runs.
Old 06-15-2007, 08:24 AM
fuseone's Avatar
there is a tsb that a knock sensor can make a noise
Old 06-15-2007, 08:58 AM
01trans am's Avatar
well i'm going to try running 93 octane and see if that helps. I also thought that what you were supposed to run but where i bought the car said to put 87 in it but i'll try that and hopefully that will help
Old 06-15-2007, 09:07 AM
SSsuperdave's Avatar
I replaced both of mine cause of a miss-fire and a low voltage code. I think I only paid like 65.00 or 70.00 bucks. Mine were full of water, I'm guessing from washing my motor off. After I replaced 'em, I put a little RTV around the caps and try not to soak the motor when washing it.
Old 06-15-2007, 10:43 AM
TheLS1Kid's Avatar
Yea dude, definitely do not run 87 anymore.
All LS1's deserve 93 octane.
Old 06-15-2007, 03:38 PM
Xtnct00WS6's Avatar
The knock sensor is about a 40dollar part from SDPC. It does not make a noise, it just picks up acoustic vibrations. Like others have said, use 93 octane.
Old 06-15-2007, 03:45 PM
gun5l1ng3r's Avatar
I use 91, and my car will knock in the lower RPMs under high load. I wish we could get 93 here in California.
Also, I think that having 126K mi on it, it might have some carbon in the combustion chambers...
I also think part of the the problem is my PCV is sucking a little too much oil vapor for my likes I had a "Walmart" cathcan on it a while ago and it seemed to trap a decent amount of oil. I took my oil fill cap off the other day and a little bit of smoke seeped out for a few minutes.
I do have the regular LS1 knock sensors, not the updated ones(I think they had an update to keep the moisture out), I think...
Old 06-15-2007, 03:55 PM
Da Swami's Avatar
Amen to that.
Old 06-16-2007, 12:22 PM
01trans am's Avatar
well put went ahead and put half tank of 93 and it seem to help alittle so i'm going to try and run a few tank through it and see what happens
