1LE LCA bushings
Old 06-15-2007, 08:40 AM
qwikz28's Avatar
Default 1LE LCA bushings
does anyone have the part number for the 1LE LCA Bushings? i found this:
1LE rear lower control arm bushings (93) = 10164152
but it says its only for 93 model years. is it any different for every other year? is it difficult to install? thanks
Jacob
Old 06-15-2007, 09:59 AM
LS1TECH Sponsor
Sam Strano's Avatar
I can help you with those.... $52 for the set of 4. Just need pressed in (not hard if you have the press and proper sized dies to push on the bushing sleeve.
__________________
18 SCCA National Championships in house, many more for our customers prove we know our stuff.Talk is cheap, results matter.
Check out our KONI prices, our Master Cylinder Brace, and new Xtracker Hub/wheel bearing upgrade kits!
Old 06-15-2007, 12:34 PM
z28bryan's Avatar
So those bushings can't be put in using any easier method? Do you have to use a press.
Edited post because my question before was too vague
Old 06-15-2007, 12:42 PM
LS1TECH Sponsor
Sam Strano's Avatar
They're press fit..... Might be able to do it with a really big bench vice and a big socket set (like 3/4" drive sizes).
__________________
Old 06-15-2007, 01:15 PM
gun5l1ng3r's Avatar
So if we do have a smaller bench vice and maybe a 1/2" socket set we would be screwed trying to put these in?
Would the next best thing be, to just buy the LCAs w/ bushings already in them?
Old 06-15-2007, 01:19 PM
OldeSkool's Avatar
Get the bushings and go to your nearest machine shop.. its easy to do with the right tools.. they shouldn't charge very much
Sam, how do the 1LE bushings compare to the Moog problem solver bushings?
Old 06-15-2007, 01:22 PM
LS1TECH Sponsor
Sam Strano's Avatar
You could just have a shop press them in for you.
__________________
Old 06-15-2007, 01:27 PM
gun5l1ng3r's Avatar
I thought the bushings that Sam was talking about are the Moog bushings???
Also Southern Orange County Kalifornia does not have an abundance or hardly even one machine shop... It just isn't the same as the rest of the country...
Old 06-15-2007, 01:59 PM
Greggy's Avatar
I used these directions to do the job and they worked out great.
http://www.valvoline.com/carcare/art...=res20011101br
I drilled out the rubber material on the old ones and bought a big 3/4" socket at Autozone that fit the rim of the bushing to pound on with a BFH.
Old 06-15-2007, 06:09 PM
Viper's Avatar
"They're press fit..... Might be able to do it with a really big bench vice and a big socket set (like 3/4" drive sizes)."
That's how I did mine. Worked fine.
Old 06-15-2007, 08:22 PM
joecar's Avatar
Any brake/shock shop will press out the old ones and press in the new ones at something like $25 each hole...
inspect when done to make sure they're in sufficiently and/or not gone past,
and get the shop to make any corrections before you leave.
I'm in Or. Co. So. Cal. and yes, it is different...
Old 06-16-2007, 12:27 AM
qwikz28's Avatar
thanks for the info guys. its for a buddy with a v6 so i'll pass on teh info.
sam- do you sell them? i'll place the order next week when i call you for my shock adjustment if thats the case
Quick Reply: 1LE LCA bushings
