LS1 Edit, MAF calibration=Out of byte range
I'm trying to adjust my MAF calibration and if I multiply the table by 120% I get an error "This value is out of byte range. It will not be reset."
It's reffering to the 11250 hz value.
My MAFT is currently set at 20% rich, I was assuming the table for Edit would have to be the same to get the same results as I did with the MAFT. ????
Location: Richmond, VA Where fast cars, well......are hard to come by.
Re: LS1 Edit, MAF calibration=Out of byte range
It says that because whatever number is there already, will be more than 512 when multiplied by 120%. 512 is the biggest number allowed in the maf table. The translator doesn't have a problem, because it doesn't change this value. I believe it just changes the frequency the pcm sees.
