Sponsor Vehicle Projects & Shop Tours - Ky Turbo & Performance Shop Car
View Full Version : Ky Turbo & Performance Shop Car
Josh@KY-Turbo
06-15-2007, 04:32 PM
http://www.fquick.com/images/vehicles/full/223344742.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=44742)
Induction-
Type: 6.0L Manifold Single setup TC76MPS turbo
Manufacture: Kentucky Turbo and Performance
Boost: currently 10lbs
Intercooler: 31x12x4 FMIC
Performance-
Horsepower: 561
Torque: 564
10.91@131mph 1/4 on 315 BFG DR's.
http://www.fquick.com/images/vehicles/full/223345400.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=45400)
Engine-
Block: 6.0L Iron 370
Compression: 8.5
Oiling: Stock Ported pump
Crankshaft: Stock
Connecting Rods: Eagle 6.125
Pistons: -15cc Dished Diamond
Cylinder Heads: Ported 6.0L
Camshaft: Speed Inc TU1
Rocker Arms: Stock
Intake Manifold: LS6
Ignition/Computer: FAST XFI & FAST XIM
Headers: 6.0L manifolds
Exhaust: 3" Down Pipe to 3" bullet
Cooling System: Griffen radiator with Spal Twin pusher setup
Fuel-
Pump: Weldon 600A
Injectors: Motron 60lbs
Rails: Speed Inc
Tank: NASTY Performance
Drive train/Transmission-
Transmission: TCI super Comp TH400 RMVB / T-brake
Clutch/Converter: Yank SC3000
Driveshaft: Sphon
Rear Axle: Moser 9 inch 3.25 gear and spool
Chassis-
Front Suspension: Stock
Rear Suspension: UMI
Brakes: Stock
Wheels & Tires-
Front Wheels: 17x9 Chrome ZR1's
Back Wheels:17x11 Chrome ZR1's
Tires Front: BFG KDW's
Tires Back: 315 BFG DR's
Appearance-
Body: Stock
Interior: Stock
Race Weight: TBA. It's been lightened alot.
More track times and Mods are on the way.
Josh@KY-Turbo
06-15-2007, 04:39 PM
Here are some of the build up pics. The turbo setup fits with the factory radiator in it's factory location. I did the modifications in the pics below on my shop car to make room for the planned 91mm turbo setup and 408 the car will be reciveing one I max out the TC76MPS turbo. The current setup will gores 9's :devil: .
http://www.fquick.com/images/vehicles/full/223316778.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=16778)
http://www.fquick.com/images/vehicles/full/223316780.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=16780)
http://www.fquick.com/images/vehicles/full/223324530.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=24530)
http://www.fquick.com/images/vehicles/full/223330529.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=30529)
http://www.fquick.com/images/vehicles/full/223337616.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=37616)
http://www.fquick.com/images/vehicles/full/223337617.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=37617)
http://www.fquick.com/images/vehicles/full/223337618.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=37618)
http://www.fquick.com/images/vehicles/full/223337619.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=37619)
http://www.fquick.com/images/vehicles/full/223337620.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=37620)
http://www.fquick.com/images/vehicles/full/223337622.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=37622)
More updates to follow.
Josh@KY-Turbo
06-15-2007, 04:42 PM
I have ordered a complete AeroSpace drag brake setup and manual brake setup form BurkHart Chassis for the front and rear of the car. As well as some 15x10 & 15x3.5 ProStars with MT 26x4.5 Front runners and MT 325/50/15 ET RD's.
http://www.fquick.com/images/vehicles/full/223346100.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=46100)
I have a S&W mild Steel 10pt cage that will be installed in the car soon.
Josh@KY-Turbo
07-31-2007, 08:26 AM
Well the shop car has big changes in store. I am in the process of pulling the turbo setup that is currently on the car off and putting it up for sale to make room for the new setup. I had planned on a S88 setup, but have decided to go for broke. I am going to do a 91.5mm thumper setup.
-91.5mm Turbonetics turbo A/R 1.39 F-trim.
-6.0L manifolds (unless I decide to build some tube headers)
-JGS 60mm Waste Gate
-JGS 56mm Piston BOV
-2.5" charge pipes
-4" Downpipe
-3" intercooler pipes
-Staying with the current FMIC (yes Air to Air)
-Dual nozzel Meth injection
I am not looking to run a certain class or anything like that. I just like to push the limits of a street/strip car. I will still bring the car out on the occasional weekend cruise, and will have it at the strip plenty (with a truck and trailor so when I break it I can get back to the shop).
I plan to run it on the current 370 to see what it is worth unless I sell that engine to fund the 408 build. It is all a toss up right now in the engine department. I paln to keep the TH400 though I am gonna need to have the Yank verter restalled from its current 3000 rating. I will be doing 3.50 gears in the rear, and running the 325/50/15 MT DRs on the stock width 9 inch rear.
Like I said before. I am not building the car for a certian class. I have always wanted a thumper turbo street strip car. I have the opprotuinty to build one and that what I am gonna do. I hop to have it ready and on the road for the Ford weekend event this fall.
Sneek Peek at the turbo:
http://thumb14.webshots.net/t/52/452/1/71/24/2489171240047301034ICwRPu_th.jpg (http://rides.webshots.com/photo/2489171240047301034ICwRPu) http://thumb14.webshots.net/t/30/466/7/83/76/2708783760047301034WWiAgl_th.jpg (http://rides.webshots.com/photo/2708783760047301034WWiAgl) http://thumb14.webshots.net/t/62/462/4/70/20/2933470200047301034ICBPia_th.jpg (http://rides.webshots.com/photo/2933470200047301034ICBPia)
Josh@KY-Turbo
08-19-2007, 07:23 PM
I finally finished the AeroSpace Brake install and got the new ProStars and MT front runners and DR's on the car. As of right now I have sold te FAST XFI setup and am going back to a stock engine harness and eigther a stock PCM with HPT or an AEM ECU for the tunning. I want my factory gauges back. I am goong to stick with the current eingine setup and turbo setup that the car has now and see what it is made of. I enjoy driving the car to much to make it a full out race car just yet.
http://www.fquick.com/images/vehicles/full/223360587.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=60587) http://www.fquick.com/images/vehicles/full/223360586.jpg (http://www.fquick.com/garages/viewgallery.php?action=viewimg&id=60586)
