Power steering reservor question
Old 06-15-2007, 11:11 PM
kirtondog23's Avatar
Default Power steering reservor question
I have installed a 04 LQ4 into my truck and my 1990 steering box only needs two lines while the reservor has 3. I capped one of the lines on the reservor so I can just use my two lines and this works well except that the red rubber cap that I put in the third line from the reservor leaks pretty bad. I think it is sensitive to the heat.
Any suggestions as to where I might find a better cap. Maybe a thicker real rubber one or something? Have any of you had to deal with this?
Thanks
Old 06-15-2007, 11:54 PM
sawzall wielding director
G-Body's Avatar
The second return line on your reservoir is for the return from the hydroboost brakes that were on the donor vehicle. You could either get a reservoir from a truck that did not have hydroboost.
Or you may be able to find a brass compression fitting that will fit on the second return line and then use a brass pipe cap to cap it off.
Old 06-16-2007, 08:30 AM
hosspowerinc's Avatar
Is it possible to use a high pressure fuel line cap and put a clamp around it?
