Changing oil filter
Changing oil filter
This may be a stupid question...but how do you all change your oil filter with Long Tubes???? I am having the damndest time getting a filter wrench on the thing. I can't even get it tight. Are there any tricks or am I just an idiot?
If I can't get this tonight...is it bad to change the oil, leave the old filter, and drive tonight and tomorrow until I can get it to a shop?
Thanks in advance.
Thanks in advance.
Well the screwdriver trick didn't work....kinda. The old, time-tested method of pushing a screwdriver through the filter worked, finally. talk about a mess though! Thanks for the input guys. Next time this won't be a problem as I won't be going to Valvoline anymore.
Originally Posted by INMY01TA
What filter is it? If it's a short one I could see how it would be harder to get a filter wrench on it with a long tube in the way. I run the AC Delco pf 61, comes down far enough to get it on there.
Originally Posted by Rescue Ranger
Get a K&N Oil Filter. It has a nut on the bottom of the body to allow easy on/off. Perfect for cars w/ Longtubes.
yup what he said, best filter out on the market right now.
