Replacing the TRex....Options?
I'd like to replace my Trex with something a bit smaller. Give me some alternatives that will improve driveability without sacrificing power.
My current setup is:
ARE Short block (Stock crank/Rods, ARP bolts, Forged Pistons)
PRC Stage 2.5 LS6 Heads with Double Springs
Cometic Head Gaskets .040
T-Rex cam
Hex Adjustable timming set
ASP Underdrive Pulley
Fast 78mm Ported intake
Ported Stock TB
QTP 1 3/4" Long Tub headers
Custom 3" H-Pipe into two Dynomax Ultra Flow mufflers Dumped
4.30 gears
6 speed
T-Rex cam
Ported Stock TB
4.30 gears
6 speed
LS1 Tech Administrator
With the excellent exhaust flow, I'd recommend a single pattern cam and a little wider LSA. 236/236 .615/.607 112LSA +2. This will give you around the same DCR and power peak as the T-Rex, but with 12 degrees of overlap verses 25 degrees at .050".
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by Phil'sC5vette
Im just curious, why do you want to change.
What about the Torquer 3
I'd almost beleive it was tuner related...if I hadn't seen the magic he's worked on countless other vehicles.
trex
Originally Posted by Ebbsnflows
Already milled...11.3/1 CR.
Those look like good, REALISTIC numbers to me. Not the inflated internet numbers that a few shops put out, but realistic, accurate ones. Nothing wrong with that setup. Change cams like Patrick G said. Or get an adjustable timing chain and back off the cam's advance a little.
