Who makes Adj. rockers for ETP's?????
Old 06-17-2007, 10:04 AM
SpdfreakLS1's Avatar
Default Who makes Adj. rockers for ETP's?????
I need a set and i heard that Jesel is the only one so far and they are 1400.00 bucks!!! Anyone know of another company?
Why does it even matter? If stock rockers work why cant a stock design Jesel work?
Old 06-17-2007, 10:16 AM
1997bird's Avatar
T & D Machine products can make you a set. You need to call and talk to them about making you a set to fit the heads. http://www.tdmach.com/ More than likely they will be cheaper than Jesel, around $1,100 to $1,200.
Old 06-17-2007, 12:23 PM
DONAIMIAN's Avatar
The stock rockers only work on the ET heads if the specific ET rocker arm pedestal is used. The design of the Jessels do not use a pedestal pedestal at all. For the ET heads, the acuall Jessel rocker arm itself is prolly the same, but the shaft it mounts to is different.
