Koni SA trouble
Koni SA trouble
Today while I was rotating my tires I decided to tighten my Koni SA shocks up front for a little summer time performance. I decided to adjust each side to the absolute negative side (zero) and then back to my desired setting. However the one side ended up turning like 17 times when I know the absolute zero point for the shock is only 12 turns at max. What could be wrong with this shock? Should I send it back to Koni for their warrenty and how does that work? Also with the other side I use to get 12 turns out of that for the full cycle but now I only get 9-10, is that normal. I've had my shocks for like 3 years, I got them from Sam Strano.
Busted shock. Send it back for warranty. You can get advance replacements for a refundable charge. Mine only go 8-9 turns, but they redesignded them a little I think.
