Line lock problem ??????
Old 06-17-2007, 11:05 PM
bowtierodder's Avatar
Default Line lock problem ??????
my line lock has been working great since i installed it a few months ago with several trips to the drag strip. but my last time out when i did my burn out in the water box, the line lock wouldnt quiet hold all the way. as soon as i started spinning the wheels my car would start to creep foward, i always engage the line lock with the same procedure and was wondering why its not keeping the brakes locked completly. it works.... but just not 100% like before, and i cant heat up the tires enough
Old 06-18-2007, 12:11 AM
Duffster's Avatar
possibly leak-by on the valve? yank it out, clean it up and reinstall it. Check your connections, it could be loosing power/solenoid not holding/slipping.
Other than that, press VERY VERY firmly on the brakes before engaging the lock.
Good luck
Duff
Old 06-18-2007, 08:59 AM
thanks ill try both
