DO i need to change the gear of cam???
Old 06-18-2007, 02:31 PM
camaro_best's Avatar
Default DO i need to change the gear of cam???
hi guys my Q
DO I need to change the gear of cam ???
with new cam ???
lift cam under .600
and if need to change it .
is the ls2 timing and gear cam fit on ls1 directly ?
or Just buy timing without gear cam??
the car mile / 56K
Old 06-19-2007, 12:22 PM
anyone??
Old 06-19-2007, 05:09 PM
Dragula's Avatar
Originally Posted by camaro_best
hi guys my Q
with new cam ???
lift cam under .600
the car mile / 56K
It is a good practice to install a new timing set (cam and crank gear with chain) when installing a new cam. I would recommend a double roller for strength.
I don't know if the LS2 timing sets are compatable.
Look for an LS1 based timing set from the sponsers list on the right. I've purchased parts from both Thunder Racing http://www.thunderracing.com/ and Speed Inc www.ls1speed.com.
Old 06-19-2007, 05:16 PM
LowBird's Avatar
bought my ls2 timing set. ended up only using the chain as my gear/sprocket looked really good for 75k on them.
