descreening my maf?????
Am i askiing for trouble when i descreen my maf. will that trigger any of the sensors to come on. reason for doing this.... is i'm about to install my slp lid and i want the best airflow possible..
((((((Administrator))))))
Just be careful if you pop it out not to damage the sensors (wires). Also some people with A4 cars have issues. I have no first hand proof of that, both of my cars are M6.
Peace,
Craig.
Originally Posted by CRAGER
I have done it on both of my cars, hell my Granatelli MAF's don't even come with a screen.
Peace,
Craig.
Peace,
Craig.
+1. You should be allright, but just be carefull. The Z/28 was de-screened (the very first thing I did when I got home) and never had a single problem, code whatever. My SS has the screen in it right now, but I'm fixin' to run a small dry shot so the screen is about to go.
you will not see any gains and it can screw up the tunings. The screen promotes linear airflow for proper reads.
Most tuners, will make a customer buy a new screened MAF before they tune a car if yours is descreened. Also stay with the stock MAF. Aftermarket MAF can cause tuning issues, and stock MAF still work fine on big builds.
I have a 85mm SLP MAF and it was a pain to tune...
Also if you run an oil based filter make not to over oil the filter, it can cause many issues if oil flies up and covers the maf... It can even cause problems with A4 shifting!
my slp lid has some sealing issues. I open it up every few months to clean it and there are always a few small seeds or small leaves that the screen saves the motor from. The power gain is not worth the expense of new MAF
Originally Posted by camaroextra
A4 here and there is no problems shifting. It probably doesnt matter either way what you do with it.
its becomes an issue, not from the descreaning but from too much oil on oil based air filters.
The oil coats the resisters on the maf and can really cause pcm issues.
GM will not warranty problems on a car if you have an oil air filter!
1 Post
Ohh I see. Stock paper filter here lol.
1 Post
Originally Posted by dailydriver
Your other alternatives to this are the higher flow, cleanable/reuseable, NON-OILED filters, i.e.; Amsoil EaA 83 or Fram Synwash (don't know the #).
Mines been descreened for about 2 years no problems. I can't say I saw a big difference in doing it but I would not recommend against it. Pop it out with a screw driver from the opposite side and save it. If you do feel the need to put it back you always can.
For those saying it makes no difference and can affect tuning... Well that is BS. Check out SLP's website and look at there MAF they specifically state that taking it out increases the CFM and recommend it for race only cuz there Lawyers say so
don't descreen the MAF... not worth it...
No screen does NOT screw up tuning in any way whatsoever.
Most tuners do NOT make you buy a new one with a screen.
You do NOT need to stick with a stock MAF. More so with a FAST 90/90 set-up. You need the bigger MAF.
Jayson (MTI Owner) is one of the best LS1 tuners around, so I trust his judgement. So for my 427 SS with the FAST 90/90 set-up he said to go with the Granatelli 85mm MAF (does not come with screen) because the SLP 85mm leans out up top.
I have ran my SS without a screen for 6-1/2 years now, zero problems. I bought my T/A used 3 years ago and the screen was one of the first things to go. Again, zero problems. A tune will help as well.
Peace,
Craig.
1 Post
I had some debris in my MAF when I first took a look before I removed it. I suspect it was from previous owners that didn't know how to reattach the lid. If you have a proper filter and properly slip the tabs home, there shouldn't be anything getting through.
As for the airflow... In the how-to book, " How to Build High-Performance Chevy LS1/LS6 V8's" by Will Handzel (who was a program manager working on development of the LS1), it states uncategorically in Chapter 3 that it is OK to remove the MAF screen. In fact, he suggests "The simple modification that should be performed to every MAF sensor is the gentle removal of the inside screen."
I quote from his book, "The screen is used to straighten the airflow coming into it to minimize false airflow readings, but on LS vehicles with straight intakes, the screen isn't required. On trucks, where the air tube approaches the MAF from the side, the screen should be left in unless you're willing to make calibration changes to account for the new readings."
So, listen the the naysayers, think a while, and take your pick. I say go ahead and remove it. Though my SOTP meter isn't finely tuned, I did feel a bit of increase in the crispness of throttle response.
