who knows????? pelase
ok well first of all my clutch resivor is not holding fluid but im not having any fluid puddles under the car. i cant get my car into gear without turning it off and then starting it back up. with my pedal pressed all the way to the floor while the car is in gear, if my foot is not on the break the car acts like im letting out of the clutch and is trying to drive.. my pedal only gets pressure about 6 inches from the floor. what the ****??? haha is it my clutch?? master?? slave?? all ?? thanks
wrencher
Check the clutch master rod where is connects to the pedal under the dash.
Right at the firewall there is the backside of the master, see if it is all wet. if so you need a master cylinder.
my experience says that its the slave cylinder...i had the same issue, but due to the way the inside of the bellhousing slopes down and back, i didnt get any fluid until someone told me to try jacking the rear of the car up. then clutch fluid poured outta the weephole at the front of the bell housing...if you get fluid, its the slave, if not see if theres fluid around where the master cylinder push-rod comes thru the firewall. if there is its the master cylinder.
-cam
-cam
