**Ultra small metallic color stuff in my oil**
Old 06-19-2007, 10:27 PM
Hell'sChariot's Avatar
Default **Ultra small metallic color stuff in my oil**
Today I noticed there is SUPER fine metal particles in the oil, almost like dust. The magnet wouldnt even touch them they were so small. Is this normal after a cam swap? Maybe just the cam breaking in? I dont know. And its only when I change the oil. Meaning when I check the dipstick the oil looks clean.
The car runs hard as hell, and there is no knocking at all.
Old 06-19-2007, 11:24 PM
SS101's Avatar
if they are that small and still metallic colored, my instincts say aluminum...aluminum is one of the few metals that still retains a silvery metallic reflectance when reduced to very small shavings - even in a powdered form. i'm not sure if that narrows it down at all...there's a lot of aluminum in the ls1
Old 06-20-2007, 01:12 AM
BIG BAD BLACKSS's Avatar
A little bit could be attributed to the cam breaking in. It can also be a cam bearing dieing though.
Old 06-20-2007, 07:22 AM
BIG_MIKE2005's Avatar
Yea, you definetly need to keep a close eye on it. No matter what kind or form of metallic material you see in your oil, it's bad. I would say if it's possible to park it & freshen up the short block, that would be your best bet.
Old 06-20-2007, 07:39 AM
mr. Jones's Avatar
did you install a double roller timing chain?
Old 06-20-2007, 10:24 AM
nope, just a LS2 chain.
I figured it had to be bad, and what really sucks is its my daily car, and dont have a place to pull engine or money to rebuild...man I have the best luck possible sometimes.
Old 06-20-2007, 06:33 PM
OldSchoolFormula's Avatar
moly lube? That will make a pearly/metallic look to the oil.
Old 06-20-2007, 07:00 PM
I did use belray moly lube w/solids. How long would it take to wash that out? I have gone about 200 miles and am about to change the oil again, it has been 100 miles since the last change, which was when I discovered it.
Its weird because you cant see the any metal in the oil, its just when the light hits the oil it lights up like a christmas tree. And nothing on the drain plug at all.
Old 06-20-2007, 10:32 PM
jvanleuvan's Avatar
Could take a couple oil changes. If everything sounds fine, oil pressure isnt changing and theres no small chunks of metal I wouldn't worry about it.
Old 06-21-2007, 10:19 AM
morning bump...
Old 06-21-2007, 07:47 PM
night time bump....
Anybody else have any input?
