Heat Shielding for MC Line
Old 06-20-2007, 12:35 PM
gun5l1ng3r's Avatar
Default Heat Shielding for MC Line
In an effort to try and keep my pedal from going soft 45 mins after I bleed it, I am going to try and add some heat shielding around my MC line.
My question is, does it matter what kind of sheet metal to use? Or can I just use any malleable metal sheet(steel/iron, not Aluminum)? Do you think Ace Hardware might carry what I am loking for?
Thanks for the help!
EDIT: I have already wrapped the MC line in fuel hose from AutoZone and 3M foil tape ($7.99 a roll!!!!). I am talking about adding some stock style sheet metal to kind of 'seperate' the MC from the exhaust pieces...
Old 06-20-2007, 09:11 PM
gun5l1ng3r's Avatar
Any help at all
Old 06-20-2007, 09:25 PM
ski23's Avatar
same troubles here. I snagged some insulation wrap from a steam tracer line at work. its a fibermesh wrapped with aluminum then covered with high temp rubber. right now my line is wrapped with fuel line and aluminum foil, still have the trouble.
Old 06-20-2007, 09:51 PM
gametech's Avatar
Just make sure the shielding is nice and shiny to reflect radiant heat. Any paint or corrosion will lower the effectiveness.
Old 06-21-2007, 03:35 PM
gun5l1ng3r's Avatar
Thanks gametech! Would some sort of galvanized or aluminized, or even Stainless work to keep the corrosion away?
