Banging under car
Old 06-20-2007, 02:30 PM
koji777's Avatar
Default Banging under car
Guys, now that I've got most of my suspension mods I have a little prob. I have Sphon adj control arms, Lakewood adj Panhard rod, Sphon adj Trq Arm. I know the car would be a little stiff, but now I have a hard banging under the car when I take off, almost dead center rear of car. I am also running a Strange 12 - bolt. Any Ideas? It's hard to figure since that car only does it when starting off or if I down-shift with out bringing rpms up fully to match the speed of the car.
Any help or suggestions appreciated.
Mark
Old 06-20-2007, 05:02 PM
ap2000z28's Avatar
I have the same noise. I am pretty sure it is the lca bushings not being lubed up but i could be wrong. Also my rod end phb makes noise. Drives me crazy man I know how you feel
Old 06-20-2007, 05:25 PM
DuronClocker's Avatar
I had the exact same problem.
I fixed it by drilling out the LCA mount holes to 1/2". Stock they are 12mm, and a lot of aftermarket LCAs use 1/2" bushings, but you still need to use a 12mm bolt, so there's some play in there, definitely enough to make some loud bangs. I got it when starting with any kind of power, downshifting, slow upshifts, and when going over bumps. Now its all gone
Old 06-20-2007, 05:55 PM
BobDoLe's Avatar
hard banging on the center of the car on take-off or downshifting?
how does that sound like anything but a busted tranny mount?
jack the car up and use a crowbar to see if you can "easily" lift and move the tailshaft of the transmission (sits right on a fat rubber mount on a crossmember). i just had to replace mine and it was torn in half.
Old 06-20-2007, 10:01 PM
bradl1982's Avatar
Yeah, I would check out your trans mount. My car did the exact same thing you're describing. I changed out the tranny mount and it went away.
Old 06-20-2007, 10:27 PM
:duh: Overlook the obvious. I was thinking LCA problem because I just dealt with that recently. A transmission mount is distinctly different from LCA noise though. A busted tranny mount will make it sound as if the floor beneath the center console is going to have something shooting out of it at you. LCA noise definitely sounds like it is behind you.
Old 06-22-2007, 03:12 PM
koji777's Avatar
Thanks guys! I'm on it!
Old 06-23-2007, 01:30 AM
Ryan33187's Avatar
scared the **** outta me hwen my trans mount broke lol
Quick Reply: Banging under car
