Notices
TH400 for your T56
Old 06-20-2007, 07:17 PM
02BlueFirehawk's Avatar
Default TH400 for your T56
My TH400 has about 250 break-in miles on it.. and I'm looking for someone to do an even swap. Not looking to pay extra. This tranny and converter alone are about 2k new. I need your working (not broke, aka not a I think it's ok but makes noise) T56 for an ATI TH400 w/ ATI torque ~3800 stall converter, pro shifter, and custom drive shaft, etc below.
Reason is I want to make my car less of a race car and more of a street car for better saleability. Plus I have some supras in the area that need to get some spankings... need that 5th 'n 6th.
I will however also consider built and functioning 4L8xe w/ converter.
Things I need from you:
Basically everything to make the tranny work if you have it.
Flywheel (if you have it)
T56 w/ bellhousing
drive shaft
M6 Tranny mount
Pedal assembly with clutch rod and brake rod clips
shifter pressure plate
shift linkage, shifter, upper/lower boots, etc.
master/slave hydraulics w/ mounting hardware (ubolts)
and all other related bolts
(I'm going with aftermarket clutch/pp and flywheel but would like those as well if you have them)
Things you get from me:
1330 yoke driveshaft shop drive shaft
ATI TH400 Race tranny w/ plugnplay speed sensor reluctor.
ATI Custom built Comp. Torque converter
ATI SFi flex plate w/ ARP bolts
B&M Pro shifter (manual reverse, with pull up reverse lock.. best design imo) and linkage
Custom Stainless Tranny Dipstick Tube
Pre-welded bung in pan for included 2 5/8 tranny temp gauge (autometer procomp)
Custom modified tranny mount to fit TH400.
all related bolts you need.
3 jugs of atf
Would prefer a local yokal.
Old 06-20-2007, 07:37 PM
john3daly's Avatar
Willing to split anything up?
Old 06-20-2007, 08:43 PM
Restricted User
98Z28CobraKiller's Avatar
I need everything but the driveshaft and the tranny.
I have an MN12 (GTO/Vette T56 with the cone syncros between 2-3 and 3-4 and more agressive gearing) with about 24K stock power GTO miles. Spec 5 clutch. Spec Steel flywheel. 6 month old hydraulics. Pro 5.0 shifter. Grey console. Stock crossmember. Poly mount.
PM me if you can get rid of the Tranny and driveshaft and we can work something out.
Old 06-20-2007, 08:44 PM
Domstic1's Avatar
I have a complete setup located in Salt Lake City if your willing to ship. PM Sent.
Old 06-20-2007, 08:59 PM
red83's Avatar
Location: sneaking in your back door as you leave!/cartersville ga
i have it all also. flywheel needs turned or it may be useless. clutch pedal assembly , have all hydraulics. i jut switched to a 400, but it never hurts to have a extra one lying around.
Old 06-20-2007, 10:05 PM
o1m6ss's Avatar
i have the complete setup u r looking for. i am in pa(pitt) and i would be willing to meet u half way for the swap. my t-56 is from an 01 ss with 17000 miles on it pm me if ur interested.
Old 06-22-2007, 12:30 AM
hey guys, I posted on a local easternfbody.com and got a call this a.m. from a local shop who has a customer willing to trade out, so I will be doing this locally. thanks for your interest!
-Rob
Quick Reply: TH400 for your T56
