Adjusting spohn suspension.
I just got a 2000 SS with Spohn Torque arm, LCA, panhard bar and relocation brackets. All with solid ends. Where do I read about setting this suspension up? I would like to know how before I go to the track with it. Also is it normal for all of this to be fairly clunky driving on the street?
The torque arm is quite noisy. The noise I normally hear is from the bottom center of the car on decel. I have all Spohn suspension.
The only thing you need to adjust is the torque arm. Get an angle finder and set the TRUE pinion angle to -2*, that is, the angle of the pinion is pointing 2* lower than the angle of the driveshaft.
Enjoy your traction!
