l92 heads on an ls1?
Old 06-21-2007, 01:09 AM
kistlerjm9's Avatar
Default l92 heads on an ls1?
im aware the bore inorder to use these heads needs to be at least 4.00. i was wondering, however, how far u can bore a stock ls1 block safely? has anyone tried to put the l92's on an ls1 and what was the result if you did? thanks for the help.
Old 06-21-2007, 06:26 AM
PREDATOR-Z's Avatar
LS1 bore is 3.898
It can be bored to 3.905>3.910 (depending on year of block)
So no L92 heads can't be run on LS1, but on LQ4/9 (ie: 6.0) they are in the game.
Old 06-21-2007, 07:52 AM
Custm2500's #1 Fan
silver-mod-o's Avatar
bad valve shrouding issues when ran on an LS1... even a bored/sleeved LS1, get yourself a LS2 or iron LQ4/9 block and go from there.... You'll be golden
Old 06-27-2007, 12:07 PM
Sandmann120's Avatar
I thought I had heard of someone offering the L92 style head that was designed to be used with a 3.905 bore. I'll see if I can find more info.
Old 06-27-2007, 12:18 PM
PREDATOR-Z's Avatar
That is a small bore L92. Special edition ported.
Old 06-27-2007, 12:20 PM
Do you remember who offers it?
Old 06-27-2007, 12:25 PM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/generation-iv-internal-engine/724276-etp-11-degree-l92-castings-small-bore.html
Old 06-27-2007, 12:36 PM
Thanks.
Old 06-27-2007, 02:39 PM
the_merv's Avatar
Go 6.0l Block and build it..no replacement for displacement.
