Brake booster blockoff?
Old 06-21-2007, 01:12 PM
shifty`'s Avatar
Default Brake booster blockoff?
Quick question, search didn't answer:
Anyone have a solution or readily available part number to block off the power brake booster hole on the back of the intake manifold?
Just curious. I'm sure I could rig something up to block it off by shaving the bung off the original and taping over the hole, but I'd prefer something not so ghetto.
TIA
Old 06-21-2007, 02:19 PM
stealth71's Avatar
Like cover the entire thing, no MAP? Or just the brake port? Can't you just get a vacuum cap that size?
Old 06-21-2007, 02:31 PM
Mike454SS's Avatar
Would the plug GM uses on the hydroboosted (2500HD and such) trucks with LQ4's fit an LS1/2/6/7 intake?
Old 06-21-2007, 02:43 PM
shifty`'s Avatar
I suppose that could work.
stealth71 - i would like to simply plug the port for the booster vacuum line. it's like a half inch hose though, so i think vacuum caps are out of the question.
Old 06-21-2007, 02:48 PM
MrDude_1's Avatar
GMs solution to that is nothing more then a vacuum cap... you can get one that size at any good autoparts store.
Old 06-21-2007, 02:58 PM
jeepinpete's Avatar
I'd recommend getting one from GM. It may just be my luck, but vacuum caps from part stores alway dry rot within a year...
Old 06-21-2007, 03:19 PM
Rodder's Avatar
I decided to switch to hydroboost after installing my engine. I rigged it until the next time the engine is out... trimmed back the hose some, and shoved a rubber stopper in it. Lowes has rubber stoppers in the same hardware section (in the drawers) as grade 8 bolts.
Old 06-21-2007, 10:26 PM
eagleuh1's Avatar
Check GM dealer. I think its like $.98 for the plug for hydraboosted intakes. Mine had one but I pulled it and bought the fitting for hooking up the brake booster hose, again, like $.80.I'll look for it and measure it . When you get the chance, measure the hole size you need to fill.
Old 06-22-2007, 03:40 PM
shifty`'s Avatar
Ok, will do.
If anyone has the part #, it's probably cheaper from the dealer than to run all over town and find something. Part # would be superb.
Quick Reply: Brake booster blockoff?
