Forced Induction - mustang d1 headunit
00formLs1
06-21-2007, 07:30 PM
my buddy is selling his procharger d1 kit and i was wondering if it was possible to get it to work on my formula. i tried a search but didn't find much. i did see something about it spining a different way.
its off a 2003 Gt. i would probly only use the head unit and intercooler. if it was possible.
Tudds
06-21-2007, 08:55 PM
It needs to be reverse rotation
eb02z06
06-21-2007, 09:19 PM
If it's off a mod motor it will work-you may need to reclock the oil slinger though.
andereck
06-22-2007, 03:03 AM
A 4.6 blower up to 2004 will work on an F body, you'll just need to rotate the volute, the slinger is in the right spot.
00formLs1
06-22-2007, 07:49 PM
By rotating the volute do u mean moving the head unit cover so its in the right direction?
The volute is the outer cover with the discharge, just loosen the allen bolts and move it where you want the outlet to point. There are no gaskets or seals, it can go in any position, you will have to move some of the bolts around naturally.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
