Mikey 97Z M6
06-22-2007, 01:44 PM
OK, I was going to build this shortblock myself, but have recently changed directions and now I'm buying a used 388 shortblock. :devil:
For Sale:
BLOCK/CRANK/FORGED PISTONS HAVE BEEN SOLDB]
-99' LS1 block, this block was Chriss' (99Blanco) original engine. He sold it too me last year when his bottom end developed a dead hole. We tore it down to the crank and didn't see any scoring from the rods. The crank is still installed, and it spins very freely so I doubt it has a spun main bearing (did not remove mains). All the bores look great and still have the original hatching clearly visible. .......................SOLD......................
-99' Stock Crank, same as mentioned above. ........SOLD........
-99' Stock rods/pistons, same as mentioned above. Rods have been stamped with original locations, and will include original bearings for your inspection. Looking for 45.00 OBO [B]<<<<---PRICE REDUCED
-I also have some slightly used (dyno time only) 2618 forged custom CP pistons. These are flat top design with valve reliefs. They are for a stock stroke, and 6.125" rod with floating pins. These are used, but have been fully cleaned and have a fresh new friction coating on the skirts. These slugs are as close to new as you can get while still calling them "used".
Specs:
Comp. Height = 1.311
Bore = 3.903
Forging # = 96-2
Intake Valve Relief = -0.08
Exh. Valve Relief = -0.06
The pistons come with the following:
Brand New Total Seal Moly Rings
Brand New .927" Diamond pins
Brand New Spiral Locks
........................SOLD...................
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/1.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/2.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/3.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/4.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/5.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/6.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/7.jpg
http://i34.photobucket.com/albums/d136/Bowties4evr/Misc%20Junk%20-%20Temp/CP-Pistons/8.jpg
-Will make a combo deal for: block, crank, stock rods/pistons. 425.00
-Will make a combo deal for: block, crank, forged pistons 700.00 OBO
Will have pics of most items by this evening.......
I can meet you northern dudes in Longview for the larger items, or I can ship the smaller items at buyers expense.
Have a nice day........ :)
Mike
For Sale:
Specs:
Bore = 3.903
Forging # = 96-2
Mike
