idling 03 yukon
idling 03 yukon
my 03 yukon when first cranking, and at different times will idle up and down,i took to shop and it has no codes , and they ran supposedly a vaccum test.everything with nothing wrong.what to do????????????????????
Are you sure it' s not the AC compressor kicking on? All engines idle up and down to a certain degree, what range does it vary in? Which engine? You' d probably get a better responce from Newbie Tech, or the GM section of the Performance Trucks forum, link up there ^^^^
My car idles like that from time to time. It also sticks at like 1,000RPM, after a burnout at the track sometimes. I' ve never figured out a cause, or had a problem because of it.
