Gears & Axles - my used 4.10s whine
mvvette97
06-23-2007, 11:34 PM
I am sure I have them set up right. Could this be because of them being used and not knowing the exact wear pattern? Like tooth to tooth. It's not real loud but I can hear it after I hit like 60 or so.
mvvette97
06-24-2007, 07:38 AM
:lurk:
keliente
06-24-2007, 12:50 PM
Could be that they are either not set up right or they have worn a certain way that makes noise.
staringback05
06-24-2007, 05:12 PM
probably not shimmed right....OR...amount of fluid....some gears whine anyway
keliente
06-24-2007, 06:17 PM
probably not shimmed right....OR...just the type of fluid your using....some gears whine anyway
Fluid doesn't cause a whine.
LMz28
06-24-2007, 06:42 PM
who installed them? if you dont check your backlash carefully and set your shims accordingly itll whine.
trembles
06-25-2007, 11:09 AM
they will whine even if you set them up right
mvvette97
06-25-2007, 12:55 PM
I installed them. I have done several and never had a whine at all. I noticed it didn't seem as loud as it was tyhe other day
staringback05
06-25-2007, 04:15 PM
lack of, can...i should have made that a better statement....fixed
staringback05
06-25-2007, 04:16 PM
if youve installed several before have they all been the same type?, all gears have a tendancy to whine....mine do with no load around 50-60 when just cruising
They probably whined before you got them.
wrd1972
06-26-2007, 07:45 PM
I have set up three 10 bolt rear ends with 4.10' all wined. I know they were set up right, I have done many R&P's on Jeeps. There is just something about the 10 bolt?
Mine have a slight wine that is easily overlooked. Setting up used gears is very difficult to do compared to new.
All the Dana 30's I did with 4.10's were dead silent.
mvvette97
06-26-2007, 08:03 PM
Yea I wonder if it is because of the used gears. Like another guy said, they may of whined a little before. It's not very loud at all. With the windows down i can't even hear it.
staringback05
06-27-2007, 12:01 AM
ahh hell ^^ thats normal then...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
