General LSX Automobile Discussion - Removing baffles from WS6 hood Scoops?
hepcatws6
06-24-2007, 06:06 PM
Hey, guys! I think I may have asked this in a thread along time ago, but I was wondering if anyone has removed the baffles from the hood scoops on the WS6. It looks like you would get at least a minimal gain by cleaning it out. Also...how much work was it? Possible cons of doing it? Thanks in advance.
WS6 Rampage
06-24-2007, 06:42 PM
Did it to mine. infact,... you can see it in my sig below. I used a saw-zaw to remove the two 'Rain Deflectors' in the hood. Its pretty simple. Built a funnel out of T6 aircraft aluminum to incert in the void to direct airflow straight into the airbox also. Took about 3 hours to cut em out and build the new funnel all together.
02NBMWS6
06-24-2007, 06:48 PM
an easier and more reversible way of doing it then using a sawzall would be to drill the rivets that hold it in out. the other two were glued on iirc? the only possible downside might be getting water into the intake tract, but i highly doubt that would happen
ws6 rampage, any pics of the air channel you made?
LS1W66
06-25-2007, 11:32 AM
I've had mine done for 8 yrs and through all kinds of weather conditions with no problems. Unles your shoving a firehose in the inlets you will be fine.
sapper5000
06-26-2007, 12:07 AM
Don't do it you will get water all up in the engine bay and intake, just happened to me 5 months ago while driving home against the rain (very hard rain, hydroplaning like crazy). I forgot the baffle was gone, pulled over and there was water all up in the filter.
7901 WS6
06-26-2007, 11:10 AM
For those who had the chance to get the BG ram air mod, You got it made with the rain blocking plate. Others that still want to remove the baffles, I would just remove the rear plate only and leave the fronts just incase you do go out in the rain or get caught in it... just my .02
Omega Doom
06-26-2007, 02:30 PM
For those who had the chance to get the BG ram air mod, You got it made with the rain blocking plate. Others that still want to remove the baffles, I would just remove the rear plate only and leave the fronts just incase you do go out in the rain or get caught in it... just my .02do you have some kind of link to it?
5301113
06-26-2007, 02:38 PM
I think it's to much work for no or minimal gains. If your car is daily driver i wouldn't do it. Keep the rain out of your filter.
Sharpe
06-26-2007, 02:54 PM
I think it's to much work for no or minimal gains. If your car is daily driver i wouldn't do it. Keep the rain out of you filter.
+1...
2001somws.6
06-26-2007, 03:05 PM
I took mine out years ago and never had any problem with water in my filter or any issue. I drilled the rivets and popped it out very easy. :)
7901 WS6
06-26-2007, 03:45 PM
http://www.geocities.com/brian98ramair/index.html
Killer
06-26-2007, 04:03 PM
I did this to my ws6 i just poped out the little rivets and then it came right out
I used the BG ram air mod which totally rawked!
If you need help PM me I think i have a tutorial somewhere i made for someone.
Dal1as
06-27-2007, 04:07 PM
If you're going to seal the intake to the lid it's worth doing for a good working CAI (Ram Air is a lie).
As for rain. I'm debaffled, have the hood sealed to the intake, and have never had water issues and have driven in plenty of downpoors. I would use an oild filter though as the filter will get a little wet.
chemicalstylez
06-27-2007, 06:06 PM
+1 :cheers:
