Trans Or Clutch Problem????
Old 06-24-2007, 10:22 PM
dave70's Avatar
Default Trans Or Clutch Problem????
Went to the track and had problems.At high rpm(6600)the trans would not go into gear,it did not grind just didn't go in 3rd or 4th and somtimes 2nd.Well after a few passes i just got pissed and jammed it into gear still no grinding just took more force than at low rpm. on one pass it jumped out of fourth.And at the end of the night the cluch pedal would only come about half way up. The clutch was slipping pretty bad(stock clutch 114,xxx miles) So what do you guys think ? what's the damage?
Old 06-24-2007, 11:02 PM
2000Z28ls1's Avatar
possibly bad slave cylinder mine went bad and I couldn't put it into gears and I had no clutch pedal check your clutch fluid level
Old 06-24-2007, 11:11 PM
wrencher
wrencher's Avatar
Read the Manual trans FAQ top of this section for one.
But sounds like you need to spend lots of $$ soon to make all those woes go away.
Clutch, hydraulic's possible trans rebuild if it keeps popping out of gear etc.
Old 06-25-2007, 09:48 PM
dave70's Avatar
Damm that's about right.Well on the bright side i did get my money's worth from the stock clutch. lol
Quick Reply: Trans Or Clutch Problem????
