is a 200 amp alternator overkill??
i plan on running lots of electrical assecories (about 10 nexus gauges, 200 watt sub (yeah i know it's small), electronically controlled air suspension, nitrous and boost controllers, two external cooling systems (one for the trans and one for the diff - each has a 12v pump and heat exchanger w/ fan) cut outs, and a bunch of other little goodies)...whatdo you think?
It definately won't hurt to have one
Maybe on a cheap, POS alternator. Mine puts out over 100 amps at idle.
Originally Posted by transam5.7lt1
200 amps are great! But I hear they work like stock at idle, its until you get the rpms a little over 1200 when they work.
I always wondered if it didn't take more power to turn a bigger amp alternator? Would you gain or lose power depending on increasing or decreasing from 160 to a 200 amp alt?
It all depends on the pulley. Mine is a direct replacement... didn't gain or lose any engine power, just gained electrical power
