View Poll Results: How to bleed clutch correctly?
1.Push in pedal 2.open bleeder 3.close bleeder 4. release pedal
43
70.49%
1.open bleeder 2.push in pedal 3.close bleeder 4. release pedal
18
29.51%
Voters: 61. You may not vote on this poll
Correct Way to bleed Clutch???
So I did the drill mod and was bleeding my clutch afterwards. The first method I used after pumping the clutch about 100 times was like doing brakes: push clutch in, open bleeder, close bleeder, release clutch. This did not get any pedal feeling. I then went on to do the other method: open bleeder, push pedal in, close bleeder, release pedal, which got some pressure back to the pedal and I got it back to where it was drivable. Searching the site, I found that most people use the second method, but usually bench bleed the master which I did not do. Is it better to use the first method after the master is semi- bled out? I also purchased a mityvac, but even with this the clutch is still not fully disengaging during mid to high rpm shifts. I am going to do the manual bleed and flush out all the fluid and try mityvacing it again. Any help would be appreciated...
Originally Posted by wrencher
I even close the bleeder just before the flow stops just to be sure the master doesn't bottom out & 'bounce' in turn sucking air.
wrencher
Originally Posted by vettenuts
How do you figure this, opening first will only initiate gravity bleed.
I like to close it before flow stops to keep it from getting air when the master bottoms out.
wrencher
If you bench bleed a master do it with the line installed. You have to depress the center core of the line where it attaches to the slave.
Then release it before the bottom of the master's stroke.
Repeat until bled.
Repeat until bled.
Originally Posted by MeentSS02
I bought a Motive pressure bleeder so I never have to worry about it again. That along with my slave extension is the "right" way to do it for me.
Kleeborp the Moderator™
Originally Posted by SLOWblackZ
I thought it was a vacuum bleeder and as I said in my post I bought a Mityvac... same thing i believe
Yep, the Motive and slave extension will work wonders. If you do a search, there's some info on it. It's been a year since my new master, slave, slave extension, drill mod, Motive power bleeder, and all is still great - can bang third without any notchiness....
