Sponsored by: DashLynx
Water stains on ALL my windows and t-tops
Old 06-25-2007, 12:04 PM
Gallstaff's Avatar
Default Water stains on ALL my windows and t-tops
I have the most stubborn water spots in the world on all of my windows. I've washed, windexed, clayed, and used just about every autmotive glass cleaner out there but they can't be removed. I don't want to use steel wool as some have suggested sine I'm afraid that it will cause more harm than good, but I'm going crazy here. How do I get these off?
Old 06-25-2007, 12:31 PM
kaos_'s Avatar
i've heard some people using steel wool to remove the numbers that are put on your car when you go to the track and it doesn't scratch the glass. i guess it's microfiber? just what i've heard!
Old 06-25-2007, 01:03 PM
xBROKEx's Avatar
use that CLR stuff from home depot with a microfiber
Old 06-25-2007, 01:27 PM
Gallstaff's Avatar
The clr isnt too abrasive?
Old 06-25-2007, 01:29 PM
xBROKEx's Avatar
no, i would avoid getting it on paint but a bunch of people use it on their glass
Old 06-25-2007, 02:18 PM
99zee's Avatar
vinegar and water mixture in a spray bottle works also.
Old 06-25-2007, 03:13 PM
Rawr256's Avatar
Chrome polish on windows. Did it on my buddies car who has tried everything possible, clay bar and all that stuff and he nearly crapped himself when I did it on one of his and it was all gone.
Old 06-25-2007, 04:46 PM
PERFECT Z28's Avatar
You can claybar your windows to remove water spots, if they're really stubborn, you can use a fine steel wool.
Old 06-25-2007, 05:28 PM
SilverSmoke's Avatar
You can use steel wool, but IT MUST BE 0000 STEEL WOOL! Anything more coarse than that will scratch your windows. When I was in a pro shop we used it all the time, it's too fine to scratch glass.
Otherwise, just use any polish you would use on your car and a machine, or polish it by hand.
Old 06-25-2007, 06:57 PM
kerryt1's Avatar
there are people (auto restoration supply type people) who sell glass polish.
Old 06-25-2007, 09:57 PM
LS1_Unleashed's Avatar
P-ming you now with stuff that will take all of the water spots off the glass, i have the same problem and it worked like a dream for me.
Old 06-25-2007, 10:14 PM
Ceissus's Avatar
haha ok here's how you get them out!
first let me tell you what i tried first:
windex
tropic-care glass cleaner
amonia
vinegar
lighter fluid
all of the above with a #00 steel wool
all of the above with a razor
soap and water
carb cleaner
alcohol (85% electrical cleaner grade)
anything else you could think of.
only thing that DID work is some "headlight defogger" from auto zone.
apply it to an orange tropic-care cutting pad and go to town on your glass with the PC buffer(i used speed 6). It took about 20 mins per window and after ward they were absolutely spotless. they looks brand spanking new!
hope this helps!
p.s. This product DOES have amonia in it so be careful as not to get it on your paint. i'm not sure how it can affect your clearcoat etc.
Old 06-25-2007, 10:56 PM
_JB_'s Avatar
I use Zaino's glass polish
Old 06-25-2007, 11:09 PM
Camaro Z's Avatar
Try some Isoprophyl Alcohol
Old 06-25-2007, 11:15 PM
Black_Bird's Avatar
pmed you, problem solved, 100%
Old 06-26-2007, 10:54 AM
windex
amonia
vinegar
lighter fluid
soap and water
carb cleaner
hope this helps!
Sounds to me like you had glass etching, not water stains. #00 steel wool would have scratched your windows so you would of needed to polish out anyway. #0000 steel wool is what you should use.
Old 06-26-2007, 11:28 AM
Ceissus's Avatar
yeh whatever it was, was BAD!
all gone now though
Old 06-26-2007, 02:18 PM
ultraz's Avatar
what did it
Old 06-26-2007, 02:23 PM
wannafbody's Avatar
Zaino glass polish and a PC
Old 06-26-2007, 03:45 PM
What do you think caused though tough water spots?
Acid rain?
Quick Reply: Water stains on ALL my windows and t-tops
