Notices
WTT my Double roller for your LS2 Timing set
Old 06-25-2007, 06:11 PM
ROCNDAV's Avatar
Default WTT my Double roller for your LS2 Timing set
I have a rollmaster double roller set that I bought for $120 some time ago.
I installed the set on my engine, degreed my cam and checked PTV. I want to start closing this bad boy up but I am thinking about moving over to an LS2 timing set as I already have a shimmed windage tray due to my 4.125 stroke. I don't want to also mess with with adjusting the pick up tube any more than I have to, and by going with the double roller, I will have to more than likely grind the front cover a bit .
I don't have the box for the set any more, because I gave the OEM gears and chain to someone and shipped them all in that box. I will need the LS2 Timing chain as well as both the crank & cam gears.
I will provide the two gears, chain, spacer shims, bolts (from the kit) and if I can find them, some button head cap screws which should help with the clearance between the bolt heads and front cover.
Old 06-26-2007, 11:20 PM
ROCNDAV's Avatar
anyone?
Old 08-13-2007, 12:54 PM
ROCNDAV's Avatar
last chance...anyone?
Old 08-13-2007, 12:57 PM
7 Second Club
Phil99vette's Avatar
I've got a new chain and sprocket/cam gear. Do you have all the parts for the double roller?
Phil
Old 08-14-2007, 01:22 PM
ROCNDAV's Avatar
Yup, the shims are included. everything but the box (I shipped my original stuff to someone in it). I can take pics if you want. I just ask that you send the stuff first. upon receipt I will ship mine. You can check my trader rating and PM any body I dealt with if you need to confirm how I do business.
