help! need a little info about a paxton supercharger, way to low boost,
Old 06-25-2007, 08:15 PM
Thule's Avatar
Default help! need a little info about a paxton supercharger, way to low boost,
my friend has a supercharged 97 anniversary car, it has an PAXTON Novi 2000 supercharger, and its only boosting 3psi? isint that way to low? how much should it be? and what could be causing this,
thanks!
Old 06-26-2007, 02:36 AM
Thule's Avatar
help!
Old 06-26-2007, 08:38 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Way too low. I would say you have a leak some where.
Keith
Old 06-28-2007, 07:19 PM
Thule's Avatar
thanks man, isn't this a 6psi blower?
how is best to track down the leak?
Old 06-29-2007, 01:07 AM
DeltaT's Avatar
Belt not tight enough? It should be so tight that it is HARD to turn the longest stretch of the belt sideways 90 degrees.
That was my problem when I first started out with my Vortech 383 - I just wasn't used to the amount of tension they need for traction. Tightened it up like people here told me, and boost went up into the 6-7 range.
Jim
Old 06-29-2007, 11:29 PM
Thule's Avatar
i checked the belt, its maybe not as tigth as it could be, but its rather tigth though,
two things i i am thinkin about,
this car still has the stock manifiolds and Y pipe, could that effect how much the paxton is boosting?
other thing, the damper seem to be damaged, it shakes realy much when the engine is running, this is the only thing that drives the blower belt, could it be that the pressure from realy tigth belt have caused that? and maybe be the answer?
Old 06-30-2007, 03:34 PM
stevieturbo's Avatar
That is not a good sign...
What engine ? What model of Paxton ?
If you see the damper shaking, you REALLY need to sort that issue first, before you cause damage to the crankshaft.
Has the crank been pinned or keyed to securely locate teh damper to stop it rotating ?
A blower can place considerable drive loads on this, and the dampers have been known to work loose.
Old 07-01-2007, 02:51 PM
Thule's Avatar
thhis is an 97lt1 car, with paxton Novi2000,
i saw that when the car idles it shakes, but when he revs it it gets stable,
Old 07-01-2007, 08:31 PM
will82's Avatar
Location: Somewhere Between Mild Insanity and Complete Psychosis
The NOVI 2000 is capable of twice that and more.
Old 07-01-2007, 08:51 PM
Thule's Avatar
i thougt so,
Old 07-01-2007, 09:32 PM
Jimmy P's Avatar
Have someone look at that damnper ASAP. It ended up chewing up my crank=time for a new crank.
Old 07-02-2007, 08:03 PM
Thule's Avatar
yeahh whe dont want that to happen,
any other opinions?
Quick Reply: help! need a little info about a paxton supercharger, way to low boost,
