sleeperMULLET
06-26-2007, 07:03 PM
Hey guys, I just put in my new TCI Super Street Fighter 4l60E in my 95 Z28. I have a 3.5" Moser D/S and I noticed on the front slip yoke there is a small hole at the end near the u-joint and ATF is pouring out of it. Does this mean I over filled the trans and the tailshaft is full of ATF and that is an exit for it? It didn't do it on my other trans.
performabuilt
06-26-2007, 07:43 PM
If you remove the tail from you old trans you will likley see what looks like a small tin can with and oring in it , that oring keeps that from happening but I havent noted cars having that, But have seen it many times on trucks, If it is there you can swap it over.but replace the oring , If its not some one likley changed the yoke at sometime and used silicone to seal the hole, Which I have also seen a few times. Seems to work ok well until you take the yoke back off the trans .
