Fan question?
Fan question?
I have a twin fan set up in front of the Radiator now since the Turbo is there. I want to hook up to my factory fan wiring. Which set of plugs controlls which fan ?
I want to use the fan that comes on first with the lowest temp sensor.
Then the computer will tell it when to turn them on. But I also would like to add in a switch to be able to manually work the fans. Which ECM wire is it and can I supply ground to make it work ???
Thanks ......road test tomorrow after I get this fixed.
Please help
Please help
