My90Iroc
06-26-2007, 10:02 PM
How are you guys connecting your aftermarket fuel rails/lines to the stock body fuel lines?
ChevyChad
06-27-2007, 05:26 PM
http://www.ls1tech.com/forums/showthread.php?t=698950
Nasty N8
06-28-2007, 12:08 PM
We have kits to install rails to stock lines give me a call I will set you up.
Nate
beaSSt
07-13-2007, 08:06 AM
How do you disconnect the factory rubber fuel lines from the steel lines? I have the fuel line disconnect tool for disconnecting at the fuel rails.
At the steel line it looks like a lever clamp. Do you just flip that clamp to remove the rubber part of the stock lines?
