spohn 25mm rear sway bar TOO BIG!
Old 06-27-2007, 12:47 PM
dhpewterz's Avatar
Default spohn 25mm rear sway bar TOO BIG!
I bought a 25mm rear sway bar and its rubbing my shocks and the new set of shocks i just bought it wouldnt even be close to fitting. Has anyone else had this problem?
Old 06-27-2007, 01:45 PM
coolformula's Avatar
Most people don't run more than 22mm!
Why do you "need" such a big bar?
Old 06-27-2007, 01:49 PM
LMz28's Avatar
jesus...that SB has some girth. i didnt even know they came that big.
Old 06-27-2007, 01:59 PM
DuronClocker's Avatar
Yeah, I had a 24mm from my old thirdgen WS6 on my '98 and it was WAY too stiff, and the car was wayy too tail happy. Would be great for drag racing though. I'm pretty sure that's how Spohn advertises their bar too.
Old 06-27-2007, 11:48 PM
02TransAm/Batmobile's Avatar
Damn 25mm? Any thicker and that'll be a stock front swaybar!
Old 06-28-2007, 07:30 AM
Stang's Bane's Avatar
They are for Drag racing. I have the 1" solid.
Old 06-28-2007, 08:06 AM
Swedez28's Avatar
I have the same bar from Spohn. Had no install problems and it clears my Bilst. shocks easily. What type of shocks you running? And i love this bar. It plants the rear very nicely!
Old 06-28-2007, 11:28 AM
Shockwave179's Avatar
Yeah that's what happens with too big of a rear bar like that.
Old 06-28-2007, 11:44 AM
Big rear bars and no front bar is only for track drag racing. The opposite of what you want to handle curves
Old 06-28-2007, 01:31 PM
dhpewterz's Avatar
Yeah im a drag car cam only setup trying to run some ten's but i had competition eng shock at first but now i got qa1's. The rear sway bar rubbed on the competiton shocks and the qa1's are twice the diameter of the other ones. If i bought the sway bar mounting kit would that set the sway bar down lower and give me more space between the shocks? I just mounted the sway bar with muffler clamps in stead of paying 70 bucks for the kit. Guess i shouldnt have been such a cheap *** and just bought the mounting kit lol. Any help would be great. Thanks
Old 06-28-2007, 05:18 PM
noah89's Avatar
I'm running the Spohn 25mm in the rear too with no problems. If you go through the pics in my sig you might be able to see the clearances.
Old 06-29-2007, 03:18 AM
dhpewterz's Avatar
I guess my car is just a freak of nature cause i had it set up identical to yours and it had maybe a cm of space and then when i would launch the car they would hit the shock. pisses me off I guess I will try it again and see what happens thanks for all the help.
Later
Darren
Old 07-01-2007, 09:57 AM
JimMueller's Avatar
I have an Addco 25mm rear bar on my car and don't have any fitment problems using the stock shock mounting locations. Albeit I'm using Koni's. FWIW, I do autocross and it works well for me because I lowered my rear roll center
Old 07-01-2007, 10:43 AM
lethal93ta's Avatar
mine is 1 5/16 no problems here
Quick Reply: spohn 25mm rear sway bar TOO BIG!
