Having problems LS1 Editing for 30lb injectors
I got some new Accell 30 lb injectors. The car runs so fat it barely runs.
Soooo what exactly do i change for the new 30 lb @ 45 psi injectors?????? I went through the fuel maps etc and i cant figure it out.
Re: Having problems LS1 Editing for 30lb injectors
You need to change your injector flow rate table. To lean it out you raise the values. To richen you lower the values. I would start by multipying the table by 132%. Then use autotap to check your Ltrims.
When I put my new injectors in, the truck had to run a while to learn them. It may take a while of driving, but it will compensate for them until you get tuning done usually. I know a cam puts another variable in there, but, the PCM should learn the injectors.The way I did my ltrims, I started with the flow rate table from someone with a similar setup, then adjusted my flow rate from there, using Ltrims as a guide.
