Which Clutch
Old 06-27-2007, 02:22 PM
mycamaroSS's Avatar
Default Which Clutch
ok so my clutch went out and i want to put an aftermarket clutch on it (under $500). Im pushing 340 at the wheels and 350 torque. What's a good clutch for these numbers. Thanks
Old 06-27-2007, 02:53 PM
bww3588's Avatar
might post it here. youll get better results.
https://ls1tech.com/forums/manual-transmission-14/
Old 06-27-2007, 02:55 PM
mycamaroSS's Avatar
yea i probably would, thanks
Old 06-27-2007, 03:00 PM
bww3588's Avatar
what year is your car? if its a 01-02 i would go with an LS7 clutch. but it its a 98-00 your going to have to change master cylnder and slave cylnder, so its going to run about $770 bux. otherwise, without thoes, it shouldnt be more than 500 shipped from SDPC.
Old 06-27-2007, 03:17 PM
mycamaroSS's Avatar
it's an 01, but can you keep the stock flywheel if you get an ls7 clutch?
Old 06-27-2007, 03:20 PM
bww3588's Avatar
no you have to upgrade to the LS2 flywheel, but that is included in the ~500 shipped. i think its 399.99 + shipping from SDPC for just the clutch PP and FW. then its like another 13X.XX for the master and like 11X.XX for the slave.....etc...so you can see it adds up quick. im waiting for my OT paycheck to get it because i gotta get the slave and master also. so its going to be like 768.XX shipped to me.
mycamaroSS's Avatar
hey i was looking around and this spec 3 clutch kit is for sale would this be a good kit aand can i use my stock flywheel?
https://ls1tech.com/forums/manual-transmission/738254-fs-1-new-spec-stage-3-clutch-kit.html
Old 06-27-2007, 03:22 PM
bww3588's Avatar
spec clutches are hit or miss. i personally would never get one jsut because of the horror stories ive heard. some say they have resolved the problem, but others still post storied of their clutch coming apart and eating their legs and the dash...etc.
staringback05's Avatar
ls7 and be happy
Old 06-27-2007, 03:27 PM
mycamaroSS's Avatar
what site is this at?
Old 06-27-2007, 03:31 PM
scoggin dickey performance, their a sponsor on the right
mycamaroSS's Avatar
thanks guys
Old 06-27-2007, 03:34 PM
bww3588's Avatar
www.sdpc2000.com
http://www.sdparts.com/product/SDLS7...ClutchKit.aspx
Old 06-27-2007, 03:35 PM
bww3588's Avatar
Originally Posted by mycamaroSS
thanks guys
Old 06-27-2007, 03:36 PM
mycamaroSS's Avatar
so if i get this ls7 clutch kit from them, what else do i need to get or am i good to go sorry for the dumb questions i just need to know
Old 06-27-2007, 04:08 PM
bww3588's Avatar
LS2 pilot bearing, a can of brake parts cleaner maby a throwout bearing if your really ****, i would change the clutch fluid also just to be on the safe side.
Old 06-27-2007, 04:36 PM
mycamaroSS's Avatar
ok so i dont need the stuff you need to get because mine is an 01
Old 06-27-2007, 05:42 PM
bww3588's Avatar
no you dont need a master or slave. i dont either, but the 01+ were upgraded versions. so unless yours are bad there is no reason to upgrade.
Old 06-27-2007, 06:37 PM
hammerhead's Avatar
I got a ZO6 clutch & updated slave a couple years ago and it's a great setup. The pedal feel is light like stock with zero chatter.
Old 06-27-2007, 07:22 PM
mycamaroSS's Avatar
alright well i decided to go with the luk pro gold clutch kit, it's OEM and have only heard good things from it and also i can get it at pep boys because i need the clutch now. Thanks for all of your help bww i really appreciate your time
