awful banging sound...help
Old 06-27-2007, 07:53 PM
KD1655's Avatar
Default awful banging sound...help
Whenever I hit a pot hole or when I floor it and go from first to second, I hear an awful banging sound coming from one of the rear wheels. It sounds as though plastic is snapping. Is this a transmission problem? Thanks
Old 06-27-2007, 07:57 PM
02TransAm/Batmobile's Avatar
Do you have any aftermarket suspension? I had the same problem and re-tightened the subframe connectors and the panhard bar and the noise went away. I don't know which one of the two was causing the problem because I did them at the same time but the panhard bar was pretty loose. Other than that you might be hitting the bumpstops located directly above the rear axle.
Old 06-27-2007, 09:22 PM
Greggy's Avatar
wheel hop. check your rear bumpstops.
Old 06-27-2007, 10:09 PM
KD1655's Avatar
how would I go about checking the bumpstops slash correcting the problem. I don't have too much experience with working on suspension
